Home > General (L494) > Keylees entry KVM module |
jases4x4 Member Since: 28 Dec 2014 Location: yorkshire Posts: 237 |
I had mine do the same in my l320 about £300 from indy if i remember right. |
Sun Mar 07 2021 7:09pm |
Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 469 |
Thanks for the info. I’ll monitor it for a bit longer to see if it happens again then get it looked at.👍 |
Sun Mar 07 2021 7:19pm |
Now its working again, why not do the deactivation of the wireless signal trick it stops thieves from gaining the signal from your keys and been able to open your car with them rf extender devices they use. The keys still work for you just pressing the buttons, maybe then the keys will work fine if wireless signal is switched off from module.worth trying for a few days you can easily reactivate the wireless on the module if its the same problem then you might need to replace module. |
Sun Mar 07 2021 7:56pm |
Yeah I may try that. |
Sun Mar 07 2021 9:02pm |
