Home > General > Quandary, poorly RRS, help please! |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
The arms are relatively easy to answer as you can see the prices for OEM and pattern parts. Labour is 2 or 3 hours. Likewise O2 sensor which you can find easily enough and likely is also a relatively easy job (although being LR it could be placed in the most inaccessible place possible.
Tue Mar 02 2021 4:39pm |
Howler Member Since: 07 May 2014 Location: I'm in the Castle. Posts: 29 |
Hi thanks for your answer, the parts I have listed are all to be replaced, on the ACE system multiple leaks were found, fluid was found to be leaking from the rear pipes, and rear ACE ram and valve block, the quote I had were for all of the parts and labour.
Tue Mar 02 2021 10:08pm |
Amazing that the valve block, the rear pipes and the rear anti-roll bar itself are all leaking. Are they just doing the "throw lots of parts at it to make it go away" method?
Tue Mar 02 2021 11:33pm |
