Home > Maintenance & Modifications > L320 Wheel Arch Edge Protectors
Brit Plumber
Col wrote:
This is what you need, exactly same stuff as the Sport except 20 quid cheaper a set and you get Six pieces instead of Four and cut right will do the whole car twice, as only generally lasts a couple of years or so, although mine have been on nearly Four years now.
https://www.ebay.co.uk/itm/Genuine-Land-Ro...SwFXVZ34L6
Cheers Col, that’s a better option and genuine LR to, I bet the stuff comes on a roll and it’s just cut to a length. Probably cost pence rather than pounds. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #590167 Sat Nov 09 2019 7:32pm
PaskySNR
United Kingdom 2013 Range Rover Sport 3.0 TDV6 SE Siberian Silver
I need some as mine are shocking. Look really tatty so have taken the rear ones out. I’ve seen this tho??
https://www.ebay.co.uk/itm/BLACK-Rubber-U-...890.l49292
Post #610628 Fri Feb 26 2021 12:23pm
Seatown
Location: Moray - if you're a courier, yes it's mainland UK & no it's not in the Highlands
The trouble is that stuff doesn't look like it has the steel reinforce in it that the LR part does so it may not grip properly or sit flush against the edge of the wheel arch. I bought some of the longer Freelander ones and cut to size and had some spare left over. Pretty reasonable prices rather than buying the specific RRS ones. 2010 TDV8 - current - my first RRS, loving it so far......
2005 Cayenne S - handling defied physics and what a sound, so sod the mpg!
1995 Disco TDI- surprisingly reliable, shame about the peeling dash & other trim
Lots of other non 4X4's in between times.........
Post #610752 Sat Feb 27 2021 9:44pm
Iomegas
United Kingdom 2013 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Britpart
Hi got mine from Britpart for my RRSL320 2013 and just cut to size and a very good price https://www.lrdirect.com/LR001623-Protector-Edge-Quarter-Pan/
Post #610754 Sat Feb 27 2021 10:13pm
windsorlad111
Canada
Hi, new owner here. i need to get some of these wheel arch covers and was wondering if anyone had updated info on good ones to purchase and any updated fitting instructions??
We also regularly go back to the UK or have people visiting so getting parts from there not an issue.
Thanks in advance!
Post #643018 Wed Jul 03 2024 7:11pm
skid1963
https://www.ebay.co.uk/itm/294749579507?it...AWD+I+L320 2015 L494 SDV6 3.0 HSE Dynamic
2006 L320 4.2 Supercharged
2009 BMW X5 M-Sport - Gone
2007 L320 2.7TDV6 SE Buckingham Blue - Gone
2011 Jaguar XFS 3.0V6 Diesel - Gone
2009 (59) L320 Facelift 3.0TDV6 HSE White Wrap - Gone
2008 BMW X5 M-Sport - Gone
2005 Audi A6 3.2V6 Quattro S-Line - Gone
Post #643022 Wed Jul 03 2024 8:05pm
