![]() | Home > In Car Electronics > Bluetooth required |
If you don’t want music from the car at the same time I guess so.
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
This Kinivo is the one I use. I plug into the rear lighter socket and it links to my iPhone as soon as I start the car.
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 331 ![]() ![]() ![]() |
Thanks for your Robin!! Looking at your pictures, that is exactly what I need. Is the sound quality a lot better than your mobile offers?? I'm intrigued.....what is the device on your dash situated just above the GPS screen? Or is that the speaker for the Bluetooth??!?? Andrew Kennedy |
Robin.....I've had a look on Amazon and I cannot find anything Kinivo that relates to your pictures. I would be grateful if you could give me a few details of the system you are using. Andrew Andrew Kennedy |
Hi Andrew
Robin. The match to yours on Amazon is currently unavailable. The below AUKEY is available but I'm wondering if the description is as yours? I'd be grateful if you could have a look and see what you think.
Robin.......I must add, all I require from this device is for it to play the instructions from Google Maps - clearly, better than my smartphone offers. Andrew Kennedy |
Hi Andrew - it could be a bit of the almost blind leading the almost blind here. but here goes:
Hi Robin. Thanks for all the info and your comments re Bluetooth Speaker. If I order a match to yours from Amazon UK there is a problem of postage and now import charges , so I will have to see if I can obtain one here in France. Before I do, I am wondering if there is anyone out there who can suggest other Bluetooth Speakers that works well with Google Maps and the driving instructions?? Andrew Kennedy |
Hi Robin....So I've got the Smartphone's Google Map Directions paired up to the Bluetooth through AUX. I'm presuming while that the AUX is giving me all the directions I need, the RADIO and CD buttons are not going to be available?!? Andrew Kennedy |
I'm afraid that's correct. See my comment on 28th Feb:
