Home > General (L494) > Auto engine stop/start? |
scarey Member Since: 07 Jan 2011 Location: in the cloud Posts: 410 |
yes, disconnect the signal wire to the VQM,
Tue Feb 23 2021 11:10am |
Laurie100uk Member Since: 01 Nov 2020 Location: Bristol Posts: 37 |
*Ctek MXS 5.0 |
Fri Feb 26 2021 7:04pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
How old is your car? does it have the Aux battery or a capacitor? If its the aux battery then it could be that its drastically low or dead. if this is the case the ASS is unlikely to work as the electronics use this leisrue battery to provide assistance to all the
Fri Feb 26 2021 8:12pm |
Thanks for your reply mate. Erm it's a 2016 model and I checked in the boot and there's a capacitor in there not an aux battery. I've just put the charger on again tonight and put it in recond mode see if that makes a difference.
Fri Feb 26 2021 8:39pm |
let us know how the Ctek fairs on reconing the battery. If its the origininal battery which i reckon it probably is its ont he cusp of its warranty life span, so it might be worth see if thats an option, that sais I dont reckon LR are likely to hand over a new battery for free as its now second hand car etc... all the excuses, or they will but will charge to swap it over!
Sat Feb 27 2021 9:16am |
Hallelujah! After a one minute warm up the start/stop worked perfectly everytime. It also cleared my airbag warning light and discovered that also apparently my spare tyre pressure is low.
Sat Feb 27 2021 10:41am |
Great news then if you use the quick connector that comes with them (you will also need the extension cable, you can connect it to the battery in the boot and then feed the connector up through the wheel well and out to either side of the boot floorjust by the cargo eyelets. This way you can plug in the charger inside the boot and just run a lead out to the car and place under the rear of the car if its raining leave on overnight.
Sat Feb 27 2021 12:17pm |
