![]() | Home > General (L494) > Option of bigger washer bottle |
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
If it is optioned with the extra washer bottle then they have the trim removed from factory as you can see where it should be fitted.
Farmer Chalk Member Since: 02 May 2015 Location: London Posts: 541 ![]() |
Doesn’t the extra bottle fit under the front offside wing.... my two RRS’s (albeit pre 18MY) both had there’s under the offside wing and the cap was just along the top of the right hand wing edge... very discreetly I must say! |
thomas brown Member Since: 29 Mar 2016 Location: Norwich Posts: 559 ![]() ![]() ![]() |
Ahh OK so that trim at the o/s front is removed from factory, to be fair where it is positioned that trim wouldn't fit as the washer bottle takes up that whole area.
That’s because your looking at the standard bottle. The second bottle is just a reservoir that drains in to the main bottle in the inner wing. 2017 SVR. SVO Scafell grey Ebony interior 2012 3.0 SDV6 Autobiography santorini black with ebony/cirrus interior. Gone |
