![]() | Home > Maintenance & Modifications > RRS 3.0 TDV6 245HP '10 remap question |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
I have a MY13 5.0L S/C and sure it is the same ZF 6HP28 6 speed box, had that remapped and a upgraded s/c pulley and according to the dyno it's chucking out 750Nm of torque and that hasn't blown to bit's yet and that was five years ago.
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9029 ![]() ![]() ![]() |
The gearbox used with the Supercharged is not the same as the V6 diesel. The petrol version (also used with the TDV8) has additional planetary gears in the epicyclics to handle the extra grunt.
Not quite what this extract from the workshop manual says, which may mean the reference to "uprated" being the planet and epicyclic gearing were "beefed up", no mention of the TDV8 ever using the HP28 either only the HP26. Perhaps the first of the facelift V6's used the HP26 as well, easy enough to check though just look at i.d plate on side of box, probably has it on the build spec. sheet as well. The HP28 is rated at 650Nm by ZF the 26 being 600Nm.
