Home > Technical > Critical Warning - Stop Vehicle/Stop Safely/Stop Engine
kevin webster
United Kingdom 2012 Range Rover Sport SDV6 HSE Alaska White
I have a 2012 RRS SDV6.
The photo attached shows what appeared on the dash today.
Any ideas as to what this related to?
Thanks
Post #610253 Fri Feb 19 2021 9:47pm
I think you may need the fault codes read as sure that icon relates to either air suspension or dynamic stability control.
Post #610255 Fri Feb 19 2021 10:02pm
kevin webster
Thanks
Post #610349 Sun Feb 21 2021 2:24pm
Disco_Mikey
More often than not, that message is accompanied by a fluid leak from the ARC system
Post #610352 Sun Feb 21 2021 3:04pm
idi
That was the case with me a few weeks ago.
Post #610361 Sun Feb 21 2021 5:10pm
kevin webster
Thanks for feedback, stuck RRS into the garage.....
Leak or broken hydraulic manifold, car body had to be removed from chassis to get at the problem.
Apparently this is a common issue with RRS, Discovery etc...
£5500 later all fixed.
Post #611064 Sat Mar 06 2021 4:22pm
Johnrrs
United Kingdom 2013 Range Rover Sport 3.0 TDV6 Autobiography Zambezi Silver
Did it go to main dealer?
Post #611067 Sat Mar 06 2021 7:19pm
Disco_Mikey
£5500 Shocked
Did they replace the whole system? Confused
Post #611079 Sat Mar 06 2021 9:54pm
