![]() | Home > General > Restricted Performance (no fault codes) |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 ![]() ![]() ![]() |
Can I ask what fault scan tool you're using? |
PC76 Member Since: 01 Oct 2017 Location: Northwest Posts: 402 ![]() ![]() |
I have a GAP IID |
The inlet manifold also forms the cam cover. The two parts are "welded" together and this weld is known to fail. As for the cross over pipe, mine needed replacing recently (on an SDV6), and it didn't thrown up any error messages. Just FYI. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
The twice I have had this pop up repeatedly it has turned out to be inlet manifolds. Maybe 3 or 4 other times dpf full but fixable with a long drive on 3 occasions and on the fourth a forced regen cycle by my local specialist. |
Just taken the engine cover off and it looks like I have a small oil leak on the top left air inlet (near side) around the middle cylinder (injector covered in oil).
Puslinch Member Since: 08 Jan 2017 Location: Surrey Posts: 203 ![]() ![]() ![]() |
Mine did the same on My12, no codes. It took 4 trips to LR to fix it under warranty. It was the rear crossover pipe, along with a fuel hose that was replaced. 2018 Telsa MS
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
Managed to get round to diagnosing the issue this morning, as feared it’s a leaking LH inlet manifold. I also have leaks on the plastic inlet as can be seen on the following photos.
