Home > General (L494) > How to tell if I have AFS headlights
Red Arrow
Hi , is there an easy way to check if my sport has AFS headlights fitted ?
Post #609904 Fri Feb 12 2021 2:58pm
Eaters
One way is to remove a headlight - easy 5 minutes job and look to see if you have an AFS module attached. Like the one pictured in my post here: https://www.rrsport.co.uk/forum/topic53538.html
The quickest and warmest way (at the moment), is to wait until dark and start the car with the head lights switched on. They should perform a little "dance" as they set themselves up. Assuming that the AFS element is working.
It would certainly help if you filled in your profile so that we know what year and model you are driving. Thumbs Up Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #609906 Fri Feb 12 2021 4:32pm
Red Arrow
Okay thanks , I thought posting it under General L494 model would have been enough info to be honest Thumbs Up
Not a 5 minute job on an L494 as the bumper needs removed or at the least pulled forward at one side to look .
Looks like you have an older model L320 Sport ?
Post #609908 Fri Feb 12 2021 5:25pm
Red Arrow
Found the answer on the sticker on top of the lights - tells you what units they are Thumbs Up
Post #609909 Fri Feb 12 2021 5:30pm
Eaters
Thumbs Up Robin
Gone:
MGZTT 190 2.5
Post #609914 Fri Feb 12 2021 6:26pm
