![]() | Home > General > Shocked.. |
Do you hear the rain on the roof |
Themoog Member Since: 27 Apr 2018 Location: Cambridge Posts: 262 ![]() ![]() ![]() |
Never noticed.. Probably will now tho.
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 ![]() ![]() ![]() |
Did you have to remove the headlining to get in and repair the clip or were you able to access it without? I have the same rattle and was hoping I could carry out a fix with minimal effort for a change
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9050 ![]() ![]() ![]() |
The headlining is the sound proofing. ![]() In 2005, the RRS was just a rebodied Discovery, not a "real" Range Rover. The L494 does share stuff with the Range Rover and so more reasonably deserves that name on the bonnet. Anyway, if you haven't heard wind/rain noise from the roof, the sound deadening provided obviously is sufficient. ![]() 2008 TDV8 - it was a labour of love and is much missed |
RRT Member Since: 26 Mar 2018 Location: South Coast Posts: 252 ![]() ![]() |
On my previous car - 2013 Evoque Dynamic Lux so top spec - the rain on the roof panel in front of the panoramic roof was like a tin can, it annoyed the hell out of me. MY17 RRS 4.4d V8 Autobiography - Aintree Green (also referred to on Topix as British Racing Green) |
No I didn't remove the headlining. It was loose around the sunroof and after taking out the alarm sensor I could get a mirror in and have a look around. One clip that looked like it had velcro on it had come apart so a swift clout sorted that.
It would be more weight and cost for no benefit. As already said, if you haven't noticed wind/rain noise from the roof up to now, then it's working ok as designed. On neither of my L320 RRS have I noticed wind/rain noise from the roof area. The biggest wind noise culprit is the door mirror and there's nothing that can be done about that. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
