![]() | Home > General > Buying advise please |
Dave-t Member Since: 18 Jan 2020 Location: Glasgow Posts: 436 ![]() ![]() |
I changed from a 2016 D4 to a 2015 RRS and do not regret it one bit. It’s a different class Joined the X5 45e club
GV Member Since: 23 Jun 2020 Location: Shropshire Posts: 33 ![]() ![]() |
That is a very tidy looking motor! If it has a warranty and your friendly mech has a quick look, go for it! Haggle though, there are loads on autotrader, and I mean loads! |
Stay with the TDV8. You know it inside out and it's fully sorted. Buying another vehicle, even a "nice" one, opens you up to buying a pup.
Alfie Member Since: 21 Dec 2014 Location: Peterborough Posts: 141 ![]() ![]() ![]() |
Hi , yes I know what you’re saying, it’s been going over in my mind constantly! I went and had a look around it on the forecourt yesterday and it’s so easy to get drawn into buying what is a really lovely looking motor 🥴 I know the issues with the L320 ie bushes ,wishbone , turbos, etc and I’ve always driven my car with care and had it looked after but the L494 is something unknown to me ! I’m sure it probably has similar problems and maybe the L494 owners here will be able to inform me please 😉👍 |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
I don't know your financial circumstances but my advice would be 'you're a long time dead'.
Ditto Grimble above. They are great cars and the difference will definitely be noticed. Like I said, get the best you can afford and keep it for a good while. 👍 |
. After some consideration I’m going to stick with the TDV 8 ![]() |
Took my original 20 inch stormer wheels in for a refurb 👍 |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 174 ![]() ![]() ![]() |
Going back to your first post ..
I've done a fair amount of reading about the JLR engine failures, ie spun big end bearings, and I think it is "mostly" down to two things. 1. not changing the oil frequently enough, and 2. fuel contamination in the oil from blocked DPF's. So if you are the sort (like me) that does frequent oil changes, you'll probably find that they are fine. (Cue someone who now comes along and swears blind that they change their oil at 3000 mile intervals, and still had a problem!!) |
