![]() | Home > General > Clicking Noise |
GT RRS Member Since: 02 Feb 2021 Location: Florida Posts: 35 ![]() ![]() |
Hello, I have the same single ‘click’ issue with my 2012 RRS HSE LUX. Whenever an exterior door handle sensor is touched I get a single click from the rear valve block area behind the driver’s side rear tire (USA). Its as though something is attempting to activate, but the interior lights do not come on. I recently swapped out the rear air struts and the rear valve block so there might be a correlation there, did you ever figure out what was happening with your rig? Good to know I’m not alone! |
Phileep Member Since: 04 Feb 2019 Location: LEIGH-ON-SEA Posts: 52 ![]() ![]() ![]() |
Greetings across the pond GT RRS.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Out of curiosity just tried mine and that does it, but I don't think I will be worrying about it as had the car nearly eight years and never noticed it before, assuming it has always done it can't see it being a problem after all this time. |
Greetings from across the world Col |
Thanks guys, across thousands of miles we’re connected with our quirky yet fabulous rigs, and their unique anomalies. Here’s a quick five second video sent to my dealer rep today. I’ll let you know if he replies with any answers - not counting on it as they tend to monetize things, but you never know. Also may have been happening for the three years I’ve owned it but only noticed recently.
I have noticed that mine clicks even if you just slightly pull the door handle - gently. I have even tried
Phil, try just touching the door sensor on the inside of the handle, and you should get the click without even opening the door.
Hi GT RRS
Yes we now know how to replicate it - next is to learn why it happens! |
Not that it is of any real relevance but noticed it does it with the tailgate release as well, strange why it activates what sounds like a solenoid in the rear axle valve block thought, but I did read something about rear axle valve block being used part of the power-up diagnostic check, so perhaps it just wakes up the system somehow, but would have though that would be when car is unlocked rather than just touching the handle, and doesn't do it again straight away until system has gone back to sleep.
Excuse me for being a bit cynical with dealers, but it will probably be something like, but they all do that Sir, that will be $250.00 thank you. Cheers Col |
My thoughts exactly Col. So true. |
Indeed. And to clarify, my question was in regards to the security module idea, not whether or not the stealer - errr, dealer - wants to monetize every opportunity. Of course they do, they’ve only seen my rig for warranty work, nothing else. I do topside oil changes myself for 1/4 what they charge, and sourced new air struts from Arnott and new valve blocks, then had a local repair shop perform work. All for less than a third of the dealer quote. I do stop in once in a while to test drive the newest jaguar however |
