Home > Technical > No Auxiliary battery in RRS 2015? |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 |
I’ve just changed my big battery and I was fully expecting to change the Aux also. However when I looked I realised my car has a big battery and a capacitor rather than the AUX battery. My car was registered December 2015 but a 2016 model which is when they first started using the capacitor. 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Thu Jan 28 2021 10:29pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
I could well be wrong but I think you may find with the earlier RRS2 only the 4.4 TDV8 and cars built for cold climate market's had the Aux battery fitted.
Fri Jan 29 2021 12:59am |
bmszabo Member Since: 10 Aug 2019 Location: Tilburg Posts: 58 |
So, chapter 2.
Sun Jan 31 2021 8:07am |
CornishRob Member Since: 19 Feb 2016 Location: Gloucester Posts: 170 |
Sounds reasonable. My RRS is a 2006 model, so a bit different, but I know that manufacturers have introduced monitors in the ECU for the battery condition, which could be why your dealer is saying that it needs a "reset". The ECU need to know that the battery has changed.
Mon Feb 22 2021 8:30am |
Laurie100uk Member Since: 01 Nov 2020 Location: Bristol Posts: 37 |
Stick it on a ctek conditioner mate, my car had no start/stop and an airbag warning light. I was going to replace the battery but got the ctek mxs 5.0 instead and it fixed both the issues |
Sun Feb 28 2021 1:05am |
