Home > General (L494) > Struggle To Start when cold. |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8977 |
Put a meter across the battery when not running and then when running. What readings to you get?
Fri Jan 22 2021 11:32pm |
jason-nike Member Since: 08 Nov 2013 Location: sussex Posts: 207 |
I had the same a while ago due to lack of use and only short journeys.
Sat Jan 23 2021 10:00am |
JamieLC Member Since: 19 Jul 2019 Location: North East (Newton Aycliffe) Posts: 117 |
Sat Jan 23 2021 10:28am |
RRSTDV8 what readings should I get? Going to try this. Does the battery have to be disconnected? Also would it be possible to do so using the jump points under the bonnet? Thanks 2016 Yulong White L494 AB/DYN 3.0SDV6 |
Sun Jan 24 2021 2:21pm |
