![]() | Home > Technical > A 'different' OIL LEVEL NOT AVAILABLE problem.... |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 781 ![]() ![]() ![]() |
https://www.rrsport.co.uk/forum/topic54727...vel+sensor
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 261 ![]() ![]() ![]() |
I had mine done on my L494 last month.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5062 ![]() ![]() ![]() |
I have had this on my S/C occasionally and found if I put my toe under the throttle pedal and lift it upwards and hold it up it reads level o.k. throttle pedal position must be linked into the circuit in some way. Fortunately for me you can replace sender on a petrol variant without removing the sump. etc.
