Home > Technical > Range Rover Sport 2010 - tailgate release functionality |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
I think the powered opening only came in once the single piece tailgate was adopted. If yours has the opening glass wndow section then it won't be powered. Easy to see if it should be - the powered struts have a wire going to them as they power up and down.
Mon Jan 18 2021 11:32pm |
Vermont_Jack Member Since: 18 Jan 2021 Location: Haywards Heath Posts: 11 |
Ok thank you. It’s not powered but I thought that the gas struts themselves may be enough to open the tailgate. My previous car did this (VW CC).
Mon Jan 18 2021 11:36pm |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
Is there anyway to retrofit the powered struts? |
Tue Jan 19 2021 12:52pm |
Wafoo Member Since: 19 May 2020 Location: Pontypridd Posts: 36 |
I have a 2010 facelift and the fob just pops the lock, it's easy to open though with little effort, once I move mine a couple of feet it raises on its own, suggest your struts are a bit feeble.. |
Tue Jan 19 2021 3:53pm |
Thank you! This is what I was looking for. The struts are definitely giving up the ghost it seems. |
Tue Jan 19 2021 4:12pm |
Some people have installed the Autoease retrofit kit. They have kits specifically for the various RRS models. https://www.autoease.com/product/liftgate/ I’ll be attempting to install at some point in the next few months and will post my experience here. It’s supposed to be fairly straightforward, but others have said that running/fishing the cables can be a pain. |
Tue Jan 19 2021 4:17pm |
