Home > General > Heated windscreen not working
idi
All fuses are fine, however there is no power on the fuses when switched on. Could it be the relay?
2010 RRS
Post #608799 Mon Jan 18 2021 4:22pm
yes it could
Post #608805 Mon Jan 18 2021 5:47pm
idi
How can I test the relay? Is there another one I can swap it with to test?
Post #608907 Wed Jan 20 2021 11:31pm
It's R9 70amp grey one, same one (R7) used on air suspension could try swapping with that one. R6 is also the same but I think that is something to do with engine management, personally I would leave that one alone.
col
Post #608908 Thu Jan 21 2021 12:26am
idi
Swapped the relay with the Ride Height Control and same issue. Ride height still works fine but windscreen heating still not working. I doubled checked the fuses and both are okay, but there is still no voltage passing through them.
I did however notice what I thought was the relay clicking every 10-15 seconds or so when it was turned on. Not sure if it should do that.
What do I check next? Could it be a faulty windscreen?
Post #608930 Thu Jan 21 2021 12:52pm
So to be clear.
You start the engine.
Turn on the front heater (not fans)
And no power at the 2 fuses ? how are you checking for power?
While ON, what happen if you remove and insert the relay ? Does it click ? if not, probably a fault with the heater panel or wire or low battery
A relay clicking every 15 seconds could be the heated mirror relay
Post #608932 Thu Jan 21 2021 1:09pm
