![]() | Home > General (L494) > Headlight Xenon bulb change L494 |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 ![]() ![]() |
Yes. It’s a fiddle. But can be done by just taking out the back cover to remove bulb.
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
Ahh ok cool i might have a look then, didnt really fancy messing about with the bumper if im honest as they never go back quite as easy as they are supposed to, the old L320 head lights came out really easy couble of bolts I think and a pull tab
DZ Member Since: 28 May 2020 Location: Warwickshire Posts: 18 ![]() ![]() |
Ok cool, I bought a set of the Osram Xenarc Nightbreaker Laser DS3 bulbe yesterday form AutoBulbs Direct (also known as HID's4U) they are only up the road from me so could go an collect.
My passenger headlight occasionally flickered for about 3 weeks before giving up the ghost completely.
Davenport Member Since: 17 Dec 2023 Location: Stockport Posts: 43 ![]() ![]() |
Pjbracer1 how did the Osram’s work out?
The bulbs were really good nice and bright with good coverage, I then tried some LED bulbs that use the same power connectors and they were also really goo and so quick to react on high beam, but, and there is a massive Kim Kardashian but here, the LEDs increased the amount of mousture build up and fogging in the head light unit to a stupid level.
Thanks pjbracer1 loads of aspects to touch on in your response! like you I don’t fancy moisture messing up the lights when I’d looked at the cost of two leds from uk sellers was comparative if not in excess of the Osrams. Last night as a total punt thought I’d try the tectico items from Amazon as an experiment, claims of good stats and reviews so we’ll see how they go for now….£25 delivered seemed worth a shot.
![]() ![]() ![]() RRS Autobiography Indus RR P38 HSE V8 RRS Supercharged Santorini AMG CLK Rear Tyre Shredder Last edited by pjbracer1 on Thu Oct 10 2024 3:18pm. Edited 1 time in total |
Ffs you’re killing me those replacement headlights look dam good don’t they!! Piggy bank needs raiding, if I had one, and didn’t need decking 😢
I got them a while back direct from ALibaba before they even got to Ali express.
Well the £25 Amazon bulbs are fitted and pretty pleased so far certainly the colour temperature alone facelifts the headlamp appearance, longevity…. is a massive unknown. Managed to drop two of the airbox screws into the engine abyss though which I’ve never done before, once through wearing thick plastic gloves and secondly starting off the screw clumsily with an electric screwdriver (if anyone knows where to source spares would be great) |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1181 ![]() ![]() ![]() |
Ordered a pair of these, will report back once fitted: https://www.aliexpress.com/item/1005005009006833.html --
Martian999 Member Since: 09 Aug 2023 Location: Lincolnshire Posts: 12 ![]() ![]() |
Naks,
