![]() | Home > General (L494) > 2015 RRS - any way to get larger MPH display? |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1179 ![]() ![]() ![]() |
Nope, no other list other than 'Confirmed List' --
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
Hmm then maybe yes you need to ask to have access to the full list as I dont think this is doen by default for obvious reasons as there are some things about the safety feature in there that people could try playing with.
I asked Pat to give me all CCF, and he did, with the following warning:
will go try it out now now and report back. -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic ![]() ![]() Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
yeah i thought that might be the case, they migh appear bu might not work but its jus a skin so if one is there maybe?
ok, so I had a full list, but only one skin in the Instrument.
did you see any of the other settings like fuel guage tyep might be worht just changing that to the super charged version or one of the others to see if it changes, could always revert back to the previuos setting. normally if it wont work then it errors and rolls back.
Ah, yes, I did make one change - the fuel tank type was 'Petrol', and I changed it to 'Supercharged'.
I made my changes before I did the update on the FW so maybe rolling back to an older version would bring back the menu setting I used.
Ok, so I could not see any difference in the display after the CCF change.
yeah maybe it strange that its changed as that is the only reason why I mentioned the ability to! I reckon maybe the later version of the Gap firmware might have removed that feature perhaps or its bee split out into another function somewhere.
Well, I finally found out what changing the fuel tank from Petrol to Supercharged did: it wouldn't show a full tank when I filled up twice on a long drive today, and the calculated Range was thus very inaccurate.
Interesting well I guess we can wirte than one off as not needed then!
