Home > General (L494) > Charging
Been-and-dunit
Charging
Hello is it possible to charge the battery from the connections under the bonnet , or do I have to do as the book says ie remove battery, 🤔
Post #608473 Mon Jan 11 2021 8:21pm
Red Arrow
Best removing the battery to charge Thumbs Up
Post #608475 Mon Jan 11 2021 8:48pm
Been-and-dunit
Thank you 👍
Post #608476 Mon Jan 11 2021 8:49pm
PauloAmore
Scotland
I have charged mine on a ctek many many times with the terminals under the bonnet. Many here have.
- including a month of trickle charge during a lockdown.
What’s the concern? 2022 P440e AB
Post #608485 Mon Jan 11 2021 10:59pm
Been-and-dunit
Don’t use it much ,all I have is a battery charger
Post #608486 Mon Jan 11 2021 11:07pm
Peterh
I used a normal battery charger,connecting to the points under the bonnet when the dash warning "low battery" came up.It was sorted no problem.
Post #608487 Mon Jan 11 2021 11:34pm
Lindab
If you don't use it much, get a Ctek. You can leave it on as long as you want. It is not like the old fashioned chargers it keeps your battery at optimum charge. My F type is hooked up for abut 6 months at a time. Starts first time. Yes, use the under bonnet connectors.
Post #608488 Mon Jan 11 2021 11:49pm
knwatkins
Connectors under the bonnet are fine to use. Kev
Post #608489 Tue Jan 12 2021 12:15am
Oldandconfused
Ctek do what they call comfort connectors for their chargers that permanently fit on the battery terminals, all you need to do is lift the bonnet and clip in the charger lead. More convenient than comfort. I've seen a thread whereby owners have routed the end of the connector out of the side grille or front grille so you don't even have to lift the bonnet.
Post #608494 Tue Jan 12 2021 12:46am
Admittedly a RRS1 but here's my Ctek connector, don't have to bend down, unlock the car or flip the bonnet to connect or disconnect, don't have to bother removing tow bar cover either.
Post #608496 Tue Jan 12 2021 2:19am
Oldandconfused
There you go, it's a D4 but you get the idea (last post);
https://www.rrsport.co.uk/forum/topic39086...=ctek+vent
Post #608499 Tue Jan 12 2021 9:02am
I use the tow electrics connector. As the cover is never on, it's easy to fit the connector. Not that it gets charged very often as mine is used most days and for decent distances so it's usually got full charge in it. 2012 SDV6 - it's missing a couple of cylinders
Post #608501 Tue Jan 12 2021 1:44pm
Lindab
Previous thread
https://www.rrsport.co.uk/forum/topic54892.html
Post #608502 Tue Jan 12 2021 2:26pm
knwatkins
Or if you were feeling adventurous, you could hook up a more permanent solution like I did in my L320...
https://www.rrsport.co.uk/forum/topic55319.html Kev
Post #608513 Tue Jan 12 2021 8:20pm
Been-and-dunit
Thank you all for your support think I will get a Ctek .cheers 👍
Post #608514 Tue Jan 12 2021 8:24pm
