![]() | Home > General (L494) > Car wont start / idle |
sterling01 Member Since: 19 Apr 2015 Location: Kilmarnock Posts: 137 ![]() ![]() |
Hi, my 3.0 SDV6 wont start and looking to see if anyone else has experienced same issue for a hopeful quick fix.
flydive Member Since: 16 May 2007 Location: South Posts: 1213 ![]() ![]() ![]() |
Not exactly your problem but you ma try this
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
have you got a fuel burning heater on you car? if you have a little remote separate to the key then you have might be worth using that if you have one and see if it warms the car enough to start it if its suspected cold weather issue.
dig the signature! If a jobs worth doing, get a someone who knows what they are doing to do it! RRS Autobiography Indus RR P38 HSE V8 RRS Supercharged Santorini AMG CLK Rear Tyre Shredder |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
Faulty crankcase sensor? RRS 3.0 SDV6 HSE Lux RRS 3.0 TDV6 gone LR 3 HSE V8 gone DiscoveryII V8 Gone Discovery 1 V8 Gone Mustang Shelby Alfa Guilia (classic) |
Thanks for all the replies. Sorry, I have been off-line all day.
From what i read if the tank is half full any moisture in there will freeze quicker and then lower the temp and if the diesel does start to thicken then it cna take a while for it to thaw and turn back to its liquid state so it may been in the pipes and filters that gell quicker than in the tank.
Car started today no problem. Instantly, first touch of the button.
