![]() | Home > General (L494) > Slow sunroof |
Rowdie Member Since: 14 Jan 2015 Location: Uk Posts: 185 ![]() ![]() |
Weird, I have exactly the same issue. It sounds really laboured and moves slowly, though doesn't actually stop.
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 ![]() ![]() |
No probs I just wish I could work out what mine is as all the runners seems fine and and it has worked fine, the only thing I can think of is perhaps as it really cold -temps at the mo maybe the rubbers are just stiff an hence is being slow, thing it I dont wana keep trying it incase I do some real damage. If a jobs worth doing, get a someone who knows what they are doing to do it!
Bensrrsport Member Since: 11 May 2018 Location: London Posts: 149 ![]() ![]() |
Yep my sunroof is also the same - motor sounds laboured when closing. Dealer checked it and said its fine. |
Really! I havent tried it again et since adding some silicon spray along the runner sections and in the rubber trim on the rear section. might give it a go tomorrow seeing as its a bit warmer. I mean it does work it jsut seems slow about 3/4 of the way to close, on the slide function and a little slow on the opening but not as bad which is weird too!
