Home > General (L494) > Eye opening... |
DangerMouseUK Member Since: 16 Jul 2016 Location: London Posts: 528 |
If you have Secure Tracker Pro which is Cat 5 or whatever the new category is, they can't start the car without that exact key no as that has an extra fob inside it that disables the car?
Thu Jul 23 2020 11:49pm |
Ash3 Member Since: 31 Aug 2019 Location: London Posts: 279 |
I had my one installed late last year. The fitter told me much the same. Newer devices are much better.
Thu Jul 23 2020 11:50pm |
doncarlos45 Member Since: 06 Jan 2021 Location: London Posts: 11 |
I had my RRS 2020 model stolen a few months ago. Keys always kept in a Faraday bag well away from the front door. I suspect that they used similar methodology to what is being discussed here. Security was Secure Tracker ie Cat 6. First i heard of the car being stolen was when they tried jamming the tracker signal - 40 miles or so outside of London. No luck in getting the vehicle back.
Wed Jan 06 2021 1:37pm |
Dave B Member Since: 10 Oct 2019 Location: East/West Sussex Coast Borders Posts: 431 |
I have heard that the thieving scum will frequent a supermarket car park to 'catch' your key code, then follow you home. They then can come and get your car whenever they want.
Wed Jan 06 2021 3:10pm |
Thanks Scary website..... Not clear to me whether the driver id tag will help or not in this regard.... |
Wed Jan 06 2021 4:51pm |
That is another possibility...thanks. |
Wed Jan 06 2021 4:53pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
Also the pro thieves can grab the codes for your garage door so even that isn’t a massive help!
Thu Jan 07 2021 1:08am |
kmpowell Member Since: 23 Oct 2016 Location: UK Posts: 259 |
Wow, that is scary!
Thu Jan 07 2021 1:46pm |
They have been around for a while its basically like installing a new ECU to get the car started, its used to eb an old trick if you went to a scrap yard and took the ecu from another car (same make) and then manayed to pick the lock, bump the central locking, or packing tape your way into the car you could swap out the ecu for your scrap one and use that to start it as the imboliser was part of the ecu.
Thu Jan 07 2021 2:53pm |
