![]() | Home > Maintenance & Modifications > Fitting side steps |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 ![]() ![]() ![]() |
From memory, they go into a folded metal clip with a hole in that goes round the sill trim. It's the metal clip's hole that allows the screw to grip, if that makes sense. If you drill/strip it you can just get another screw and/or clip. This sort of thing;
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
I’ve had the same issue - you need an impact drill |
