![]() | Home > General > Gearbox issue |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
I'm not sure if I am misunderstanding your problem but with an automatic whenever you take your foot off the throttle you can expect the revs to drop and then pick back up again when you re-engage the throttle. I'd be more worried about it as you say it only occurs within the first half mile of driving. To put it in perspective, if I start up and drive down my nearby bypass - a gentle downhill - then with no throttle I get a reading of about 800-900 rpm. Once the car is warmed up if I do the same journey the revs drop to about 1200 rpm with no throttle engaged. Hope this helps but I fear that I may have misunderstood the problem. Robin
Beerlover Member Since: 22 Dec 2020 Location: North East Posts: 3 ![]() ![]() ![]() |
Thanks for your reply. Yes on a very gentle downhill slope when cold the revs will drop to 800-900 with no throttle applied and when warm they will drop to 1300-1400, and during the same time when cold it feels like the clutch slips slightly. It’s the first automatic vehicle I’ve owned so I was unsure if this is normal behaviour for an automatic gearbox. |
From what you describe that sounds normal for an automatic. If when you floor it the revs go up and it accelerates fast then I would say everything is OK. If in doubt, you could always pop back to the garage you bought it from and just check (assuming you did buy from a garage) and then at least of something bad does materialise, you have at least flagged it with them early. Robin
It's normal for these modern auto's to " if I lift off the throttle fully the revs will fall to idle"
Adding to Riverblanche's thoughts, I have a concurrent thread regarding my transmission issues, and I am now booked in with my Indie for a "Powerflush" which requires specialist equipment and is designed (I believe) to clean out most of the oil and crud. I seem to recall that the perceived wisdom is that it should be done at around the 70,000 mile mark. Robin
Thanks for all the replies, I feel a bit more at ease regarding the revs dropping but the clutch slipping does concern me, as I said I’m new to automatics and not sure if it does allow more than normal clutch slip when cold to protect other parts of the drivetrain. There is no record of a gearbox flush in the service history so I’ll get it done for peace of mind. If it makes any difference I’ll report back to here. Thanks for all the responses, best wishes to you all for this Christmas. |
LandPhil Member Since: 10 Feb 2015 Location: Suffolk Posts: 227 ![]() ![]() ![]() |
You don’t say how many miles the car has done. It’s a 6 speed box and after 10 years it undoubtedly needs a flush. Do you know if it’s been used for towing? Good start is does it have a tow bar? Towing causes the fluid to degrade more quickly.
The 2010-2012 models are the easiest to perform a flush at home if you are a DIYer.
Kev, did you run the vehicle and pump out a couple of litres of oil at a time and then pump same amount back in, until you had clean oil being pumped out? only I can't seem locate anyone near here that has the flushing machine and might have to have a go at it myself, just wondered how fast does it pumps the oil out, only I think I might be a bit concerned about pumping to much out at a time and running the transmission pump dry.
Yep, that's exactly it Col. It's easier if you have a helper so they can switch the engine on an off whilst you catch the oil.
