Home > General > Vibration under light load
Eaters
My TDV8 has developed a slight vibration when under light acceleration or gently climbing a hill. It is beginning to get worse and is occasionally becoming apparent whilst cruising at between 40mph and 50mph. Of course its appears to be an intermittent fault as I can't always notice or replicate it. Quite annoying on a recent 40mile trip to the extent that I did not stray above 40mph at any point just to avoid the possibility of it happening. And as it appears to be getting worse I am starting to get worried. If I slip the car into neutral whilst doing say 45mph the vibration still remains so I don't think its engine related.
The vibration can be felt through the floor, the seat and the steering wheel. And SWMBO notices it in the passenger seat.
From my layman's viewpoint I would have said something like an out of balance prop shaft or maybe a worn universal joint somewhere.
Any thoughts anyone?? Robin
Gone:
Jaguar S-Type V8 4.2 Sport
MGZTT 190 2.5
Post #607763 Tue Dec 22 2020 3:31pm
Initially I thought "torque converter" but if it does it in neutral then it's not that. Otherwise, a wheel out of balance can cause a speed specific vibration. Or, as you say, the prop shaft centre bearing might be worth a look at.
I would also go round and check all of the wheel nuts are tight. I had a couple of loose nuts on a rear wheel once and the vibration was very noticeable. 2012 SDV6 - it's missing a couple of cylinders
Post #607764 Tue Dec 22 2020 4:09pm
Eaters
Thumbs Up I'll have a look, Cheers Robin
Gone:
MGZTT 190 2.5
Post #607765 Tue Dec 22 2020 4:45pm
Eaters
I managed to get it to my indie briefly yesterday afternoon for a test drive. Fortunately the intermittent fault wasn't that intermittent and my mechanic could feel the vibration.
He thinks possibly but unlikely to be torque converter but reckons that, in his experience, a gearbox flush has been know to sort this. So as its booked in in early Jan for some work on the suspension compressor, he'll do the gearbox flush whilst they have it there. It was last done in January 2018 (by them) some 26,000 miles ago. Seems a bit too frequent but got to be worth a try. Robin
Gone:
MGZTT 190 2.5
Post #607790 Wed Dec 23 2020 10:33am
If it is the torque converter then a flush should help with the symptoms. But if the torque converter clutch has started to judder then it's "on its way out". As I understand it, the clutch becomes contaminated and that's what causes the judder. The flush doesn't remove the contamination but it reduces the rate at which it will accumulate as the fresh oil doesn't contaminate it.
Hopefully the flush will give you a good period before it needs more work doing. Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #607792 Wed Dec 23 2020 10:57am
Eaters
Fingers crossed... Robin
Gone:
MGZTT 190 2.5
Post #607793 Wed Dec 23 2020 11:00am
riverblanche
agree 3 years and 26k does seem a bit early for another flush, unless it was starting to get ready for work and it was just caught in time to extend its life a bit Confused
what type of "Flush" was done before
a. full transfusion
b. sump plate and filter with all oil replaced
c. dropped oil and filled back up (about 1/3rd oil replaced)
d. none of the above Laughing
Thumbs Up Porsche Cayenne 2022
gone Porsche Cayenne 2020
gone Corris Grey HSE Dynamic 2016
gone Ipanema HSE lux 2010
gone Rimini HSE 2005
Post #607816 Wed Dec 23 2020 3:25pm
Eaters
My Indie described the last one as a Powerflush - cost about £250. Well if they do it and it doesn't work I'll be looking to them to look further and not slap one charge on top of another. I can get that sort of service at a dealer and I expect more from an Indie. Shocked Robin
Gone:
MGZTT 190 2.5
Post #607823 Wed Dec 23 2020 4:59pm
Eaters
Just back from my Indie. Cost of the Powerflush including an additive (?) was £277 and no vibration. If that lasts another 20,000 miles or so before I need to fork out on a new torque converter, then I'm happy. Especially as I'm not doing many miles at the moment. Robin
Gone:
MGZTT 190 2.5
Post #608266 Thu Jan 07 2021 4:47pm
Alfie
England 2008 Range Rover Sport TDV8 HSE Lux Java Black
Hi I have a 2008 tdv8 and it's covered 115k my torque converter did same thing nearly 2years ago 15k miles ago so I had the same flush and additive and it's been no bother since so hopefully you'll be ok 👍
Post #609796 Wed Feb 10 2021 6:19pm
Eaters
Good to know. Fingers crossed 🤞 Robin
Gone:
MGZTT 190 2.5
Post #609797 Wed Feb 10 2021 6:52pm
gogsy1956
The "additive" that has been mentioned is most likely "Dr tranny" it's a friction modifier to help reduce shudder in torque converters,, normally add a couple of tubes when carrying out a flush. 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #609805 Wed Feb 10 2021 8:33pm
