![]() | Home > Technical > How often should I use access mode on a Range Rover Sport? |
If you park in a tight spot lower it.
I lower ours once a week so as the dogs are not jumping from such a height. The rest of the time it’s left in normal. 2006 2.7 TDV6 HSE in Cairns Blue. |
Use it as and when you want or need to use it. It's designed to be used.
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 ![]() ![]() ![]() |
The old adage comes to mind use it or loose it, the same goes with the hand brake use it when you want if and when it brakes it will need repairing, its the same with all motors remember a lot of us are driving 10 year plus motors heavy with all the whistle and bells from an era when a lot of this stuff was cutting edge in one motor, I am service engineer and cover warranty work on kit that cost 70k and they break down on the day of install due part failure or software issues, its just the way it is, I always go with try and buy something built on a Wednesday. |
Dont go looking for problems that are not there.
Smarttech Member Since: 11 Jan 2017 Location: West Sussex Posts: 424 ![]() ![]() |
I use to lower mine most of the time when I parked it in the L320 but now have a L494 that lowers automatically when put in park and the door opens.
I lower my L322 (and when I had a Sport) every time. Saves seat bolster wear |
I don't use access height other than for specific situations e.g. someone who is struggling to get in. But that's rare. I use off road height more than access height. |
Grimble Member Since: 21 Aug 2020 Location: Staffordshire Posts: 260 ![]() ![]() |
I use access height almost every time. My legs are long enough but my wife struggles a bit.
As said ^ every bump or corner you drive over or around can cause the suspension to adjust and use some air from the res at some point the compressor starts up and tops it back up Used access every time and off road whenever I could ![]() if the carparking was tight (airport parking) access as pulling up to let swmbo out and then offroad height to park and leave it (last one had steps fitted so less chance of car park dents!) ![]() gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 ![]() ![]() ![]() |
when am not up for lifting the dogue out the car i drop it. |
aiye hes basically the size of people |
