![]() | Home > In Car Electronics > New Android auto 12.1 Tesla for RRS 05-09 |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Hi Zeb,
zeb crs Member Since: 19 Aug 2020 Location: Lillestrøm Posts: 9 ![]() ![]() ![]() |
I shall try to figue out the bluetooth config.
The 4x4 app sounds very cool👍🏽
mrluke Member Since: 22 Apr 2018 Location: Essex Posts: 270 ![]() ![]() |
Did you guys have to root the unit to access all the system folders ? |
MrLuke,
Morning All,
Thanks Guy , Much appreciated. |
Morning All,
J50nmw Member Since: 02 Jan 2020 Location: Birmingham Posts: 15 ![]() ![]() ![]() |
Hoping to ask if we can clarify this would work with harmon kardon logic 7 I'm interested in ordering and fitting but wouldn't want to loose functionality or sound of logic 7
Out of interest do you have the link to the newer unit is it still by navihua that you mentioned and would it still be gloss black thanks again |
Here you go:
Thankyou most appreciated |
Just an update on the problems I've had and whether they've been solved:
2. "Navi" and "Band" hardware buttons have failed and cannot be reprogrammed. Again the ribbon cables came loose. 3. Internal mic not working cannot make or receive telephone calls. This was a hardware problem, the ribbon cable was loose. I've reattached it and all is good again. 4. Original Home Launcher cannot be customised. I gave up on this and now exclusively use Nove Launcher with KLWP. 5. Couldn't add an ODB Bluetooth source despite the option being available in settings as the BT app is restricted to phones, tablets. resolved through changing the config.txt file and reflashing it. Still can't get the IID Tool recognised though. 6. The screen disappears behind the frame so screen space is lost and some of the on screen OEM buttons are partially hidden. No solution as this is a manufacturing error. I noticed when I fixed the buttons and mic that the screen isn't symmetrical, rather a tablet screen in portrait mode with a wider bezel on one long edge than the other. 7. Software fix to stop the system deleting contacts when pairing phones, and allow Google sync to work. No fix provide (years long problem with FYT). Easiest solution is to disable contact sync on your Google Account settings. 8. "Car Info" displaying incorrect information, especially with regards to the suspension display. This has only got worse. After reflashing the suspension graphic has disappeared completely. No solution. 9. The system is advertised as being Android 9, but when you check it is actually only Android 8.1. No updated software provided as they have now moved to a PX6 chip (RK3399) and Android 10 alllegedly. 10. Video out does not work. No solution to date however I have found some AV software I may try. 11. Hardware backlight colour cannot be changed despite there being a setting for this. It does nothing and the backlight is always white. No solution, researching further on XDA Forum Other than the above the system does work well, and I am trolling the P4A website where they have a lot of development work for these types of units, including Android 10 firmware that should work. I trial flashed one over the weekend and had some success but the scaling was off as it was for a 1280x720 screen and not 1280x800. I can also confirm the AC vent surrounds do act as ' anchors' to some degree as I have removed them in favour of my OEM noble chrome surrounds. I will look to completely realigning the screen flush with the front of the stereo to provide better view and protection from sunlight reflections. I would then have to create a custom fibreglass back to it. And finally here's my current home screen using Nove Launcher and KLWP:
Any questions please feel free to ask. Cheers 2006 RRS S/C CONSTANTLY under modification... 1994 RRC 4.2l not LSE sadly gone but not forgotten LR Defender 300Tdi - affectionately know as "The Black Beast" |
