![]() | Home > Off Roading & Green Laning > Goodyear Wrangler Duratrac 255/65/19 or 255/55/19 |
robtheranter Member Since: 05 Sep 2020 Location: Scottish Borders Posts: 10 ![]() ![]() ![]() |
New to this so be gentle.
Mostly peat bog and deep mud use for me so should be ok for punctures |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
Just seen this. Won't the 65 profile be too much for the speedo etc? 255/50/19 is the OE size iirc but /55 is within tolerance but /65 would be a bit too much. I think that the way forward is to get 18" rims for 265/60/18 or 255/65/18.
265/65/18s here |
biasbilt Member Since: 13 Mar 2021 Location: Devon Posts: 9 ![]() ![]() ![]() |
I’ve just fitted 19x7.5j ET 47 wheels from a 2015ish RR, fitted with the Duratracs, no lift, and standard Discovery 4 sized brakes. Plenty of clearance on bumps at full lock both ways - may be 1” minimum, so room for slightly bigger tyres if needed. I can get some specific measurements tomorrow if you want them.
jk3528 Member Since: 30 May 2021 Location: stoke on trent Posts: 75 ![]() ![]() |
18” steel defender wheels with 255/70/18 Michelin latitude tyres that’s at access height overall 32.1” dia
Lrstaylor Member Since: 10 Mar 2022 Location: Kent Posts: 348 ![]() ![]() ![]() |
Being the supercharged with Brembo brakes I thought the smallest wheel was 20inch you could fit.......??? |
83series3 Member Since: 19 Sep 2021 Location: South East Kent Posts: 50 ![]() ![]() ![]() |
I looked at downgrading my 2007 tdv6 down to 18 inch wheels, but then found that I had the brembo brake option installed from factory (courtesy of Simon and PowerfulUK.com, who looked up the build sheet for me) …. Apparently you can get away with 19 inch alloys with the brembo option, but no lower.
Oh crikey - just read another post on a different thread, so looks like some 19 inch alloys fit, and some don’t …. Sheesh ….. offset research time, before more expensive mistakes are made |
But Buckster you're running Compmotive PD1881s... Lovely but not cheap! |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9025 ![]() ![]() ![]() |
Tuffant do an 18 inch steel at £720 for 4 if anyone wants that sort thing. Designed for the D4 including the SDV6 so presumably would fit an RRS too. Be worth checking with the UK supplier to make sure they'd fit, of course.
I think they are what HughN has |
