Home > Faults & Fixes > Front/Rear Wiper Washer Operation Incorrect |
Leechicken74 Member Since: 09 Nov 2020 Location: Kent Posts: 59 |
Hi all,
Mon Dec 07 2020 10:34am |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5021 |
Are you sure you have the correct owners handbook, as the way yours's work is correct for the facelift cars or that's how they work on mine, but if I remember correctly they worked the opposite way round for the 2005-2009 pre-facelift cars.
Mon Dec 07 2020 11:10am |
Hi Col,
Mon Dec 07 2020 11:16am |
If I pull the stalk towards me it just operates the the front wipers and washers, press the button on the end of stalk and it just operates the rear wash and the wiper three times if I remember right, but It may be the front that does three wipes thinking about it when you pull the stalk.
Mon Dec 07 2020 11:24am |
That makes sense and seems yours although different operates correctly whereas with mine when I pull the stalk the front washer operates with the rear wiper and when I push the button the rear washer operates with the front wipers !! total madness, seems they only half converted mine Lee
Mon Dec 07 2020 11:34am |
Only a suggestion but wonder if somebody has replaced the stalk with one from a earlier car, if that would cause the issue wouldn't even know if they are interchangeable though only a thought.
Mon Dec 07 2020 11:39am |
Thanks and when I get time I will start a process of elimination starting with the stalk and connections etc I would have considered an earth fault if it was more random but it works this way every time without fail. Still my problems could certainly be worse and I slowly getting to know the car as I fix all the many little issues and faults. Lee
Mon Dec 07 2020 12:15pm |
Thanks Andy, assume wheel off and remove the liner to access the pipes rather than through removing the headlight etc and going from the top?
Mon Dec 07 2020 12:28pm |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4996 |
done from under the car.
Mon Dec 07 2020 12:36pm |
Thanks Andy, the pipes being wrong makes sense now you have said it, I really should stop think the worst and looking for complicated issues Lee
Mon Dec 07 2020 12:39pm |
[Its odd as if I push and hold the button the rear washers runs and the front wipers operate but no washer operation on the front!! ]
Mon Dec 07 2020 7:23pm |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
100% the pipes are pushed onto the wrong outlets of the washer pump
Mon Dec 07 2020 10:33pm |
Thanks everyone, pipes switched and normal operation resumed! Must have been switched around when it had the turbos replaced as suggested, but that was 2 years ago by the previous owner so hard to believe he lived with it for that long! Anyway onto fix the next emerging fault, these cars certainly keep you busy! Lee
Tue Dec 08 2020 7:56am |
