![]() | Home > General > suspension problem |
You may need a better fault code reader.
divvy Member Since: 06 Dec 2020 Location: lanarkshire Posts: 4 ![]() ![]() ![]() |
Hi thanks for the reply,
Find out what those O and C codes mean then.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5065 ![]() ![]() ![]() |
Maybe you haven’t rebuilt it very well and made it worse then.
Hi pump runs perfect when giving it direct power from the relay, looks to me that something is not giving the signal to the ecu to power the relay, where would i find the pressure sensor on the central valve block ? pump has got plenty of pressure when removing the dryer rear pipe, thanks for the reply. |
the ecu isn't seeing a pressure increase at the sensor, so cuts the compressor off. |
Hi, thanks again for your help, i removed the compressor again and removed the solenoid and it was cleaned out as the area was covered in dryer dust particles rebuilt the compressor and it seems fine now cleared fault codes but i still get as soon as i start up the message vehicle lean when cornering and amber light lit, car drives fine, pulled codes again and there is only 2 codes
Maybe it is the hydraulic anti roll bars (ACE). I can't really help on them
