Home > General > shes on her arse... |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
The fronts and rear axles are controlled by their own valve blocks so there isn't a common point of leakage between them.
Thu Dec 03 2020 10:41am |
mgrover Member Since: 17 Oct 2019 Location: Leeds Posts: 393 |
okays, currently the supercharger and manifold is off when it goes back together ill stick it back together. but its not on bump stocks(...yet), more like its in lowered mode.
Thu Dec 03 2020 11:08am |
Going back up to extended height is a sign of a blocked compressor exhaust valve. Otherwise, a height sensor might be dying as you suggest. 2012 SDV6 - it's missing a couple of cylinders
Thu Dec 03 2020 11:21am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4999 |
The computer self levels when parked.
Thu Dec 03 2020 12:18pm |
i was hoping i wouldnt have to deal with the air bags ever honestly if its one of them i may just do all 4 and forget about it. then do the air reservoir cause its looking rusty af. the compressor is thankfully already upgraded to the AMK one |
Thu Dec 03 2020 2:08pm |
knwatkins Member Since: 09 Sep 2018 Location: Poole, Dorset Posts: 1139 |
Another fault cause when going into extended mode after selecting access mode are failed dampers that are no longer able to be compressed. This therefore simulates the vehicle being grounded on an object.
Thu Dec 03 2020 9:17pm |
Mgr it may not require damper replacement.
Thu Dec 03 2020 9:42pm |
since am a nutter who bought this car at 130k with no service history, is there a way to tell if the struts/bags have been replaced? |
Fri Dec 04 2020 8:46am |
Have a look at them. The manufacture dates are printed on the white label stuck to the aluminium shield.
Fri Dec 04 2020 9:30am |
oh definitely. if its the valve blocks ill be buzzing. but if the struts have been replaced recently then it would rule them out pretty quickly.
Fri Dec 04 2020 9:35am |
