![]() | Home > Technical > tail gate open :) |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
Had this on mine when i had my battery drain issue, it was the micro switch that had corroded which displayed tailgate open on dash but it wasn't open, try changing your upper tailgate switch, hope this helps |
ondafly Member Since: 03 Mar 2017 Location: Ireland Posts: 50 ![]() ![]() ![]() |
cheers - I actually had a spare upper tail gate switch from when I bought the car, best to be prepared and all that.
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1053 ![]() ![]() ![]() |
I've been having this exact issue. It *might* be to do with positioning of the receiving part. What I did the other day was to get a T40 torx, lift up the little plastic cover, undo the 2 bolts there a bit, pull the latch forward/towards you as much as it can go and then re-tighten the bolts. It worked fine to start with but stopped a couple of days later but it might be that I didn't do it tight enough, so will do it again & see what happens. I think I was on the right track though. |
If it doesn't soft close (whirr, clunk) then its not closed and you'll get the message on the dash. The horn sounds when you try and set the alarm on the car and any door or tailgate or bonnet is not reading as closed. Upper tailgate will not open when lower tailgate is or thinks it is. |
is there a fuse related to the soft close function ? as it seems the mechnical latch engages, but electrically its not fully closed enough to initate the soft close |
Probably but I don't know where it is |
so I am more convinced now it is the upper tailgate causing the problem.
That is entirely your choice but I would recommend checking the lower latch in the boot to see if it has moved over time (quite possibly) and to try and adjust it. Just to re-iterate, your top tailgate will not open when the bottom one is not properly closed (ie fully motorised closed) so trying to "fix" your upper tailgate when that is the case is likely to a waste of your time.
so I got this sorted |
