Home > In Car Electronics > Remote Heater |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 |
I never get steamed windows with mine, and I'm not so sure the set temp values affect it as I also use the FBH in warmer weather as an engine pre-heat so then I find the RRS fairly warm to get into until the A/C cools the cabin to the set temp. I'd have thought if the set temp value was used then it'd only heat to around that value.
Fri Nov 20 2020 2:27pm |
pjbracer1 Member Since: 25 Aug 2014 Location: Southampton Posts: 409 |
Yeah sorry ac is on all the time anyway what I meant was I just stick it on max which stocks on the window demisters too maybe I’ll give it another go on a lower temp setting and see how it goes might just be the humid air that gets in the car after I’ve set it and then get everything out of the car I guess, maybe letting in the cold damp sea air in a warm car then shutting the doors up for 4 hours If a jobs worth doing, get a someone who knows what they are doing to do it!
Fri Nov 20 2020 2:36pm |
After posting I had a thought, A P38 I used to have got steamy windows until driven and A/C on but nothing to do with a FBH, it was due to a leak so had excess moisture inside. Have you checked all carpets etc. to check dry, the moisture has to come from somewhere. 13MY Range Rover Sport Autobiography SDV6 - mine
Fri Nov 20 2020 2:42pm |
Yeah that was my initial thought too that it was maybe wet inside but Ive had a look around and all the foot well carpets seem dry. which is what was puzzling me, it might just have been that I like the car pretty hot so its warm inside already and then when I get out if Ive left the boot or door open while unloading the cold damp air rushes in and that is then locked in the car for a few hours and then when the fbh heater comes on and the AC isnt running it gets a bit steamed up, its not really bad but the rear window and the side windows to the rear seem to be the most effected maybe the blowers in the rear are shut so ill check that and have another go I guess. If a jobs worth doing, get a someone who knows what they are doing to do it!
Fri Nov 20 2020 3:19pm |
