Home > General (L494) > MY16 in for its 4 year service - rear diff pinion seal leak |
SC247 Member Since: 15 Oct 2019 Location: Staffs Posts: 60 |
Check the seat wiring for airbag issue I had this if I fully extended the drivers seat back airbag warning would come on, remove error fault would still be there, move seat forward remove error no problem. |
Fri Nov 20 2020 2:48pm |
gtr_skyline Member Since: 28 Apr 2018 Location: St Albans Posts: 245 |
Will do thanks MY16, 3.0D HSE Dynamic, Barola Black, TV, Rear Entertainment, Opening Pan Roof, Meridian |
Mon Nov 23 2020 3:17pm |
naks Member Since: 15 Jul 2016 Location: Stellenbosch Posts: 1167 |
fyi, this is it https://static.nhtsa.gov/odi/tsbs/2016/SB-10106163-9340.pdf -- 2010 Defender Puma 90 + BAS remap + Alive IC + Slickshift + Ashcroft ATB rear 2015 Range Rover Sport Supercharged V8 HSE Dynamic Defender Puma Workshop Manual: https://bit.ly/2zZ1en9 Discovery 4 Workshop Manual: https://bit.ly/2zXrtKO Range Rover/Sport L320/L322/L494 Workshop Manual: https://bit.ly/2zc58JQ |
Tue Jan 05 2021 1:34pm |
