![]() | Home > General > Rotary Gear selector intermittently sticks in neutral |
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
This is just a thought which I'll hopefully get a chance to check later today, but is there not a solenoid which prevents the rotary switch going in gear and this solenoid is operated by the brake pedal switch, probably all done through an ECU though?
PIG88 Member Since: 23 May 2018 Location: North of Watford Posts: 194 ![]() ![]() |
I had a similar intermittent problem with the rotary selector on a Jag XF about ten years ago. On that occasion, the dealer replaced the selector unit under warranty and the problem never came back. Current: 2020 P400e HSE Dynamic
