Home > Faults & Fixes > 17 fault codes.....
Jeffreyjay
17 fault codes.....
Hi all new here so hello. I've had my Rrs a week. It's a 2006 hse 2.7. It has a dashboard like a Christmas tree! Red airbag light... brake pad yellow light and several suspension warning lights. Suspension doesnt seem to work and is stuck in 1 position regardless of whether you press the buttons or not. I have plugged my scanner in and its came up with 17 faults. The main one I need sorted is the airbag light. B00D2-87. RESTRAINT SYSTEM INDICATOR 1. What does that actually mean? Where do I need to look to fix the problem? Hoping its just a wire under the seat... attached is a pic of a few of the codes written down.. thanks for any advice
Post #606620 Sat Nov 14 2020 4:18pm
jimbg
 2023 P440e SE Dynamic on order -cancelled
2022 HSE Dynamic P400e
2006 HSE
Post #606621 Sat Nov 14 2020 5:27pm
Devon Z
England 2005 Range Rover Sport TDV6 HSE Java Black
Had some of them and more Shocked don’t worry too much about the UO codes, like you said the airbag and crash record codes would concern me.
What got rid of a lot of spurious codes I kept getting was a new battery, mine seemed okay but when checked the voltage on cranking the engine it dropped below 10 volts this apparently courses problems. Steve
2005 2.7 TDV6 HSE, ongoing project.
1998 Volvo V70 R auto FWD, mothballed future project.
1999 BMW Z3 (owned from new) garage queen.
Post #606626 Sat Nov 14 2020 8:06pm
Jeffreyjay
Hi I fitted a new battery and it's still the same. I've also changed the brake light switch as someone said this could be flagging up a suspension light
Post #606641 Sun Nov 15 2020 4:27pm
Plazmapete
Just a thought. Are all the tyres the same size?
When I had to fit my spare it was a different size and my dashboard was also like a Christmas tree. New alternator.
Gearbox flush.
Post #607263 Sun Dec 06 2020 9:42pm
