Home > Wheels & Tyres > New tyre issue.... |
Tony666 Member Since: 26 Jul 2011 Location: Barry Posts: 170 |
Just to add, all tyre pressures are correct, however the speed rating on the new duratracs is 111Q, whereas the old ones are 111S? |
Sat Nov 07 2020 8:50am |
garrycol Member Since: 30 Nov 2010 Location: Canberra Posts: 1067 |
If you need to replace one tyre, there is not reason to replace the other tyre on the same axle as long as the new tyre is the same size. The difference in wear between the two is no issue as long as they are the same size. 07MY RRS TDV6
Sat Nov 07 2020 9:15am |
Sat Nov 07 2020 3:34pm |
Cheers for the replies but I think I should clarify a few points. The issues I have only appeared immediately after the new tyres on the rear were fitted, therefore very unlikely to be related to suspension faults. Additionaly, I've read a fair few comments regarding the sensitivity of cars with permanent 4wd to differences in rolling circumference (i.e. tyre size). Apparantly some manufacturers state no more than 4mm tread difference between tyres to avoid problems with the transmission? I'm not sure if this applies to the RRS as it seems to depend on the diff system used, apparantly it was a major problem on the old Freelander?
Sat Nov 07 2020 4:19pm |
1richard1 Member Since: 10 Sep 2019 Location: oldbury Posts: 178 |
I was going to say have they balanced the wheels correctly. |
Sat Nov 07 2020 6:47pm |
OK so I've been doing a bit more digging on this, and have found a bit of info on the Disco3 site. It seems that many people don't have a problem with differing tyres and tread depths, but some do. Seems prominent with tyres with aggresive tread profiles (i.e. the 12mm on the Duratracs), and seems to be on auto boxes only, the car thinking there is something wrong so the stability control kicks in.
Sun Nov 08 2020 12:12pm |
Sun Nov 08 2020 3:34pm |
Pufftmw Member Since: 23 May 2012 Location: Carmarthenshire Posts: 1052 |
Could be a host of things causing t/c to kick in. I had an issue when going into r/h bends at speed (40/50) (A/B roads) caused t/c to kick in. Got everything checked out and we had it down to a steering sensor being faulty. Replaced that and it was much better but on sharp slow(er) speed bends it was still an issue and more so when towing. I learnt to put up with it. Roll forward 18 months and I had a sticky calliper causing vibration at speed (o/s), so got a Brembo calliper repair kit and we put that on along with new discs. Hey presto, issue went on the bends. So what was probably happening is that the n/s calliper was slightly sticking but not enough to normally be noticeable but as soon as under load caused the t/c to think it was losing traction.
Sun Nov 08 2020 6:20pm |
OK so here's a bit of an update.......after a few days of low speed town driving, I took an 80 mile drive on A roads/Motorway. Weirdly, the car was better, felt a bit more stable and much less reoccurance of the stability control kicking in, only happened a couple of times on large roundabouts. Bear in mind at this point I'd changed nothing, I'm thinking the only possibilty was the car autobox adjusting automatically?
Tue Nov 10 2020 9:53pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Always worth remembering that new tyres need to "bed in" and burn off the mould release agent from when they were made. New tyres often feel slightly greasy to the touch. Have that on a damp or cold road and the tyre will be a bit lacking in grip.
Tue Nov 10 2020 11:17pm |
Thanks for the update it is good to get answers not just questions Alignment is always a good idea, just had out FL2 done with the MOT and all correct, as RRSTDV8 mentions ^ just get a few miles on them before the check. Porsche Cayenne 2022 gone Porsche Cayenne 2020 gone Corris Grey HSE Dynamic 2016 gone Ipanema HSE lux 2010 gone Rimini HSE 2005 !! |
Wed Nov 11 2020 12:43pm |
