![]() | Home > Faults & Fixes > Aarrgghhh... Anyone else had this fault? |
Is this LR specialist or a sales garage? If that fault is showing on your screen, you will have fault codes. It could be they don’t have decent kit for LRs. 2019 5.0 SC SVA (Current)
Dukie6700 Member Since: 02 Nov 2020 Location: Hampshire Posts: 7 ![]() ![]() ![]() |
It's a master technician, who worked for jaguar /land rover. I did ask whether they had the latest diagnostic kit and yes apparently they have |
Perhaps find another indie. There are a couple of members here in Ampshire so can recommend a go to place. DrRob is a Hampshire lad, he’ll be along shortly. Where are you going at the moment?. 2006 2.7 TDV6 HSE in Cairns Blue. |
I may be completely wrong here and getting confused with the pre-facelift variant as don't recall seeing it on facelift car, I'm sure someone will correct me if I am wrong, but is that icon you describe not related to the Suspension/Dynamic Response Systems? only trying to work out the connection with the cam cover gasket being replace and the cooling system needing to be drained. As suggested I think you need the codes read and possibly find a different Indi.
Hi Stevepd, The problem is the fault is being looked into by the garage I purchased the car from and they are using this other garage who are Jaguar/Land Rover specialists (independents), so I may not be able to find another garage, as it is still in warranty with them. |
Hi Col, the Cam over Gasket I think was replaced for anther fault the car had with loss of power (not related to this vehicle icon with the up & down arrows each side). So frustrating as they are delivering the car back to me today and when I drive it and the fault appears again we are back to square 1....If I had something else it could be then maybe I could speak with the garage and get them to check it, but reluctant to take this car back with a fault that clearly hasn't been fixed.. |
So in light that their garage of choice is left wanting. Can you suggest to the garage you purchased it from, that you’d like to try another LR indie of your choice and they honour the bill or you might consider returning the car...... 2006 2.7 TDV6 HSE in Cairns Blue. |
Hi, re-read your original post and obviously mis-read it as being in the garage three times for same fault, my mistake. |
Hi, so the icon is similar, it's the outline of the car, with the arrows each side of the icon. Then the message, stop the car, stop the engine, stop safely. With a red warning triangle icon above with a pinging alarm sound, but the icon of the car & arrows goes oit after about 30 seconds, which just leaves the red triangle, with the pinging sound going off a bit later.
How about this one. Could be they are talking about the Accelerometers. Although they are electrical not hydraulic. I think there is one virtually next to the D/R valve block on drivers side, the other one is mounted centreline of vehicle in the roof somewhere in the vicinity of the front interior/map light consul close to the windscreen I believe.
Hi Col, I think the icon you show is so similar to the 1 that was on my car that it must be the same, I am hoping to get the car back early next week after their extensive road testing to see if the fault message appears again after their 3rd fix. If it comes on again once I have it back I will at least have some idea of what it could be thanks to you, I will keep you posted on whether it comes on again. But after them having it 3 times & fixing 3 different things, surely there can't be any more options to try?
