Home > In Car Electronics > Urgent help gonna lose power
Craigb86
Hi I had car in garage for new alternator and battery and I've got it back just gone out three hours later and my radio display is on range rover logo. I re locked and now it's just the green head unit is there a setting that's been pressed?
Post #606254 Wed Nov 04 2020 8:24pm
Press the radio knob on then off
See if that helps
Otherwise remove appropriate fuse behind glovebox
Post #606256 Wed Nov 04 2020 8:56pm
Craigb86
Hi mate thanks for reply I think I've found what it is I'm using an AA obd charger and that is when it stays on.
So how do I work out if I drain more then I gain is the question
Post #606262 Thu Nov 05 2020 10:01am
the display will drain more than a solar charger will gain.
You can configure the rear cigar lighters to be always active and plug a solar charger into them.
or maybe its easier to hard wire the solar charger in using a piggy back fuse.
What model is the orb charger you are using? it shouldn't cause that problem. Are you sure ?
Post #606265 Thu Nov 05 2020 12:02pm
