Home > General (L494) > PSA - Front Creaking Drove Me Nuts - Fixed!
PauloAmore
Scotland
If you have a front creaking noise going over bumps or when the chassis is twisting... try depressing the A Pillar. Sounds like a creak from within the car. I lubricated everything inside until I leant on the A Pillar ...
The fix is to remove. Fill the clip locations with waxoyl as far into the chassis as possible, and replace A Pillar.
I had rubber linings off... dashboard apart etc etc. 🤣🤣🤣
Hoping this is usual to someone later. 2022 P440e AB
Post #606052 Thu Oct 29 2020 6:57pm
