Home > General (L494) > P400e Scheduling |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 |
I do not use these features in mine.
Fri Oct 30 2020 11:15pm |
Nano2nd Member Since: 23 Jul 2020 Location: Leicester Posts: 85 |
i thought I'd tried turning the settings round to test and that didn't' work either, I'll retest it.
Wed Nov 04 2020 9:01am |
so i just set the "preferred charging" time to 15:00-18:00 plugged it in and its started charging 2020 Range Rover Sport P400e HSE Dynamic |
Wed Nov 04 2020 1:59pm |
Trapdoor Member Since: 05 Oct 2020 Location: Weston-super-Mare Posts: 16 |
It took me a while to get the timed cabin preconditioning events to work. I have different departure days each day and find the app often fails first time to set the time up.
Thu Nov 05 2020 6:12pm |
i don't seem the have an option to set any timing for the pre-conditioning on the app, its just turn on or off as far as i can see? 2020 Range Rover Sport P400e HSE Dynamic |
Thu Nov 05 2020 9:12pm |
so do you set the preferred charge for 00:00-04:00 and the departure time to 04:30? or just the departure time on its own?
Thu Nov 05 2020 9:16pm |
Are you using the latest app? There are two, both work but differently.
Thu Nov 05 2020 9:17pm |
okay so yeah i was using the old app, i didn't realise there were multiple versions! okay so i've set the schedules, i'll see what happens tomorrow!
Thu Nov 05 2020 9:41pm |
It’s two different ‘climate’ systems ... the preconditioning is the Webasto fuel heater (or it runs the ventilation to ‘cool’) whereas the ‘remote climate’ runs the ICE to either heat or cool (run the air con) the car.
Thu Nov 05 2020 9:49pm |
well they say everyday is a school day! i didn't even realise there was a fuel heater? i thought that was an optional extra?
Thu Nov 05 2020 10:09pm |
Well, I’m not sure in the PHEV ... everything implies it’s a fuel heater, and mine makes quite a noise outside of the car when it’s running ... a sort of roaring noise ... and I was under the impression the small remote was for the Webasto ... so I’m not totally sure.
Thu Nov 05 2020 10:16pm |
The P400e is a wee bit different to the diesels.
Thu Nov 05 2020 10:18pm |
Ah, that explains it some ... so how do you know actually which is in use?
Thu Nov 05 2020 10:25pm |
mines a HSE Dynamic, looking at the specs the standard feature is called "Electric cabin pre-conditioning", there is a £1080 option called "Cabin pre-conditioning with remote control" (which i didn't spec), is that the fuel heater then?
Thu Nov 05 2020 11:02pm |
