Home > General (L494) > Oil leaks |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1292 |
Arb piping not covered By LR extended warranty.
Sat Oct 17 2020 10:48pm |
https://www.rrsport.co.uk/forum/topic54509.html 2022 P440e AB |
Sat Oct 17 2020 10:50pm |
Drago Member Since: 23 Jun 2019 Location: Uk Posts: 63 |
Same old excuses from independent warranty companies then
Sun Oct 18 2020 12:52am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Once again this looks like an advert for buying much more cheaply from a private seller and going for a warranty company that will actually cover the car, using the money saved from not going to a main dealer.
Sun Oct 18 2020 9:28am |
Can someone please confirm that the pipe below is part of the Arb piping?
Sun Oct 18 2020 4:06pm |
Another picture for reference
Sun Oct 18 2020 4:08pm |
.arb piping is made of aluminium Swiss cheese metal. That looks rubber?
Sun Oct 18 2020 10:30pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4969 |
Could be one of the flexible hydraulic high pressure pipe's from the pump to the system, might help if you could get a picture of where the end of the pipe is connected. Google LR043711 or possibly LR056319 would depend on Vin No. which one I think, see if that brings up any pictures that look like it.
Sun Oct 18 2020 10:39pm |
Thanks for posting the diagrams.
Mon Oct 19 2020 8:15am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Your first mistake was expecting a main dealer to be competent. Yes, they should be, but generally they aren't.
Mon Oct 19 2020 2:25pm |
Just an update, had a call back from LR dealer. Both issues will be rectified under the approved used warranty.
Wed Oct 21 2020 12:01pm |
