Home > Technical > Reduced performance warning |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
It's the fuel filter that needs changing !
Mon Oct 12 2020 11:07am |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 413 |
No fault codes showing ,,??
Mon Oct 12 2020 11:27am |
Maybe a better fault code reader is required or are you using iid ? |
Mon Oct 12 2020 11:56am |
Oldandconfused Member Since: 18 Jun 2017 Location: Norfolk Posts: 778 |
Is the car exhibiting reduced performance, or is it just the message on the dash?
Mon Oct 12 2020 12:05pm |
Thanks old and confused ..I am not now so confused !! |
Mon Oct 12 2020 1:14pm |
Hopefully for the life of your engine, it's going to be this rather than anything to do with the oil filter/oil pressure.
Mon Oct 12 2020 3:04pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
A range of issues can result in "Reduced Engine Performance" including unlikely issues like the brake light switch. Without reading fault codes, it's an almost impossible task. |
Thu Oct 15 2020 5:05pm |
