Home > In Car Electronics > retro fitting digital TV? Can this be done?
Preston-rr
United Kingdom 2010 Range Rover Sport SDV6 HSE Sumatra Black
Hi All, My 2014 RRS does not have the TV fitted, my old one did and I actually miss it so would like to know if this can be retro fitted and what is involved? Where in the North west would anyone recommend that would do this to a good standard? approx cost to do? Any help would be appreciated. thanks guys. 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #605343 Thu Oct 08 2020 11:16am
Brit Plumber
The Tv as you will know is pretty Censored , but if you must have it, it’s a reasonable retrofit if you can get the module, wiring and window antennas. It also needs activating on the FCDIM so you need SDD or similar.
Confidence in stripping your car is also a big bonus to do it correctly. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #605385 Thu Oct 08 2020 5:46pm
mrluke
You would probably be better off getting an android unit with 4G .
Then you can either stream IPTV ( Sky ? )
or you can just preload it with lots of stuff Wink
Post #605411 Fri Oct 09 2020 7:04am
Preston-rr
sounds like a nightmare, sky go on the phone it is then. cheers all. 2014 RRS HSE, SVR body kit fitted.
Black on Black
Post #605424 Fri Oct 09 2020 10:07am
