![]() | Home > Faults & Fixes > 2007 TDV8 couple of issues i need help with. |
1. Points to a faulty MAF sensor. The codes relate to right and then left sensor. As it followed the swapping, it suggests the sensor is faulty.
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 949 ![]() ![]() ![]() |
I find a lot of the time trying to lower the suspension with either my foot on the brake, or in Park it nearly always throws up this fault. Lowering the suspension when doing less than 10mph or Gearbox in neutral doesn't. 2010 RRS, TDV8
mobilemaddness Member Since: 08 Oct 2020 Location: Bolton Posts: 5 ![]() ![]() |
Thanks RRSTDV8, I was thinking the same regarding the MAF but wanted to double check before shelling out any money. There is an invoice for a new compressor in AUG 2019, Surely it cant of gone again, Only done about 2k miles max since fitted, It has been parked up as the previous owner died then I bought it. Also I forgot to mention each corner is at a slightly different height.
Been for a quick drive in it today. I have been raising and lowering susp quite a few times since last post and seems to of been fine, Wondering if low battery and lack of use cocked it up a bit. I have also used JLR SDD to adjust height of each corner so more or less the same height now. Whilst driving it, And since getting it, it feels quite sluggish, I thought these would go like a stabbed rat compared to the 2010 3.0 TDV6 I had. Would a faulty MAF create such a big loss in power? also smells quite fumy from exhausts. Thanks again in advance. |
**UPDATE**
Excellent news |
