![]() | Home > General (L494) > EV operation Question |
R22Flyer Member Since: 04 Feb 2007 Location: South Posts: 114 ![]() ![]() ![]() |
Just purchased a new RRS P400e, got and odd issue with operation of the EV which the dealer is saying it’s working fine.
The stop start does not work at all, I can do a 25 min run up the motorway and select ev when I close to home petrol keeps going.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9055 ![]() ![]() ![]() |
The user guide suggests that starting the petrol engine disables EV mode. Presumably that's why you have to stop it to get EV mode to work again. Likewise the stop/start.
gdias Member Since: 19 Mar 2019 Location: Portugal Posts: 22 ![]() ![]() |
My experience with EV mode is quite different.
Cunny678 Member Since: 08 Feb 2019 Location: Manchester Posts: 56 ![]() |
Are you using sports mode? Sometimes it like to keep the petrol engine running when in sports mode.
update, the dealer has confirmed today there is a problem, the diagnostic shows working fine, but after getting the sales person over the tech to drive the car and then drive a demo car, they confirm it’s faulty. The car is a new and worked like this from day 1, lucky I persisted, was going to reject the car next week if not sorted. Typical young inexperienced EV trained Tech ‘Computer says ok’ he even test drove the car for 5 miles with 0 EV miles and thinks this is correct.
Gio Member Since: 08 Oct 2020 Location: Europe Posts: 4 ![]() |
Hi All,
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
Your question does not make sense. If you are in EV mode then by definition auto stop/start is enabled. If you disable this then the petrol engine fired up permanently.
Thanks for your answer ilard,
Yes, if in EV mode and you then disable S/S the engine fires up, the EV light on the console button goes off, the EV light in the dash goes off, and a Start/Stop Off symbol appears in the dash. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
