Home > Maintenance & Modifications > Interior LED light upgrade front doors not working
Sinook
Scotland 2010 Range Rover Sport TDV8 Autobiography Java Black
Hi thanks for the replies , I’m going to change out the brake light bulbs today and will let you know how that goes , I can’t remember how much the leds were ? If the leds you fitted are ok would you be able to point me in there direction pls . Brake switch is an option I will try after leds are swapped thanks again
Post #605297 Wed Oct 07 2020 10:05am
Brit Plumber
I bought my LEDs from Precision LED in the USA. I was over there working for 3 months so saved on the shipping. I don’t think they’re anything special though, just good quality branded items. If you think how much some bulbs cost, the price of a good LED over a cheaper LED makes sense. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #605313 Wed Oct 07 2020 7:59pm
I used these. not cheap but lasted 5 years so far.
https://www.amazon.co.uk/Philips-127998000...B00OYT10HK
Post #605315 Wed Oct 07 2020 8:12pm
Sinook
Thanks for the links it’s appreciated, was thinking should change all leds inc the reverse light with new , I don’t trust them now ! Will order them today 👍 hopefully that clears it 🤞 cheers
Post #605321 Wed Oct 07 2020 9:00pm
Sinook
Hi mate changed the bulbs back and removed all the interior led bulbs , it ran ok for a few hours and then started again
!! Pulling the hair out now
Post #605376 Thu Oct 08 2020 4:47pm
Brit Plumber
Is the gearbox warning back? 2019 5.0 SC SVA (Current)
Post #605380 Thu Oct 08 2020 5:29pm
Sinook
Hi mate yea warnings back and when it’s jumping it jumps between D1 where it won’t change up and then D and it will , if I select command shift it says it on dash but not on the gear display ?? 🤷‍♂️
Post #605384 Thu Oct 08 2020 5:44pm
