Home > General (L494) > SVR Fuel octane sensor. |
Nilrem280 Member Since: 02 Jun 2020 Location: Portchester Posts: 84 |
Thu Oct 01 2020 6:56pm |
PDC Member Since: 13 Dec 2015 Location: Warwickshire Posts: 163 |
Many thanks for that it made interesting reading but didn’t really mention if the engine has or not a fuel sensor to actually recognise what octane fuel is going into the fuel system. 2010 RR 5.0 Autobiography
Thu Oct 01 2020 9:09pm |
Barryp Member Since: 05 Nov 2011 Location: Sydney Posts: 260 |
Doesn't the Knock sensor look after that?
Fri Oct 02 2020 7:52pm |
AS far as I understand, the knock sensor only adjusts the timing if if detects any knocking, ie if a lower octane fuel is used than recommended. An octane sensor will detect between the lowest recommended octane fuel and make adjustments if a higher than recommended octane fuel is used. Its not making timing adjustments through the sensing of any knocking but thought the detection of the higher octane fuel. 2010 RR 5.0 Autobiography
Sat Oct 03 2020 3:31pm |
Hi PDC,
Sun Oct 04 2020 2:45am |
Hi Barry, very interesting reading and many thanks for your reply........ 👍🏻 😃 2010 RR 5.0 Autobiography
Tue Oct 06 2020 1:01pm |
